Continous transmit problem
  • Hello, for my solution I need to transmit packages as fast as possible. For this, I send a message, wait for acknowledge and send another. The first 7 to 9 messages are sent fast and well, however from there, they beggin to fail (either the gateway doesn't get the message or the Module doesn't get the acknowledge), making the transmission very slow. Has anyone faced the same problem?
  • I have exactly the same problem, I am using a Multitech Conduit gateway with the LORA card. Please help!
  • I wonder if you're hitting duty cycle limitations?
    Try at+set_config=duty:off ?
  • Yes, if you use the EU868 band, the dutycycle function is default on, you can Try at+set_config=duty:off like the mikenz said.
Log in to reply
