RAK811 not joining
  • I have an RAK811. I updated it to the latest firrmware. I am using the band AU915 and I set the channel mask to 0,FF00 and the rest to 0000. When I try and join only 1 out of 50 attempts work. I can never succeed using abp and when I do finally join, I can't send data. What am I doing wrong?
    The gateway is only 2 meters away and there is no traffic going through the gateway. When I try and join i get recv:6,0,0
  • Hi, it seems that the band you changed may be changed to the default one automatically after you restart the module.
    You can try to use the new firmware of RAK811 which is developed based on keil MDK and you can config it to any band the hardware supported by AT command. After you config the band, it will never be changed automatically.
    You can find the source code and docs on Github and try to use it: https://github.com/RAKWireless/RAK811_LoRaNode
Log in to reply
