RAK831 Gateway problem "ERROR: local_conf.json is not a valid JSON file"
Hello everyone I am new to this. I am using RAK831 Gateway and raspberry pi3 B version for gateway communication.
I have used RAK831-Raspberry-Pi3-Gateway-&-RAK811-LoRaNode-User-Manual.pdf and try to make gateway online but after entering " sudo ./start.sh"
This command it shows error
"ERROR: local_conf.json is not a valid JSON file"I dont know what to do. please help!
Thanks ...
maybe you should check the local_conf.json file at /opt/ttn-gateway/bin/ .
please refer the example below, you can just replace the string B827EBFFFE2DD4A8 and router.eu.thethings.network to make it work.{
"gateway_conf": {
"gateway_ID": "B827EBFFFE2DD4A8",
"servers": [ { "server_address": "router.eu.thethings.network", "serv_port_up": 1700, "serv_port_down": 1700, "serv_enabled": true } ],
"ref_latitude": 0,
"ref_longitude": 0,
"ref_altitude": 0,
"contact_email": "",
"description": "ttn-ic880a"
