WisLTE power options
  • Hi,
    i want to power on the wislte device with the power source from Arduino digital pin.
    as per the quick start guide i should take out the jumper cap at P2 and then i can use pin 3 and my desired pin on arduino to control the power on.
    but when i took out the jumper on P2 and started arduino the board started, which looks like that jumper at P2 are not controlling the power.
    Did i understood the document correctly and does my steps are correct?
    br..
    Yajuvendra
  • I think it should be J2. Not P2. We released the Arduino library for WisLTE, which you can view here:https://github.com/RAKWireless/WisLTE_Arduino
Log in to reply
