RAK811 Lora Tracker region?
  • Hi everybody.
    Just checking in before buying some Tracker board on AliExpress.
    As of today (September 3rd) the currently available boards are marked 915Mhz. We need european radio band in our application.
    As far as I can understand the setting could me modified in firmware.
    Is it safe to assume so?
    Thanks!
  • Anyone here to answer this?
  • I am not sure if its the right choice. Some things might be different and even configuring in EU band wont perform the same way. The hardware might be designed to emit at 915 MHz frequency. Check the datasheets of both to spot any difference.
Log in to reply
