Rak811 node not able to join
  • hello,
    I am trying to connect (/join) the RAK811 node with the gateway where the RSSI(received signal strength indication) is -110 or beyond. Is there a setting in the code which restricts it to join beyond -110. Thank you.
  • administrators
    There is no such restriction in the code. What frequency band are you using?
  • I notice that in some nets Join process has low probability of success because RAK firmware use SF7 datarate when join, and can be much successful if use SF12. Sadly current firmware dont allow us to modify that.
