Why RAK831 rssi is so low ?
  • Hi,
    I'm using RAK tracker node to transmit packet to RAK831 gateway . I place both of them apart about 10cm.
    And On TTN application console, I found out rssi value is quite low which is about -75dBm.
    Does anyone know whether this is correct or not ? If not, how to solve it ? Thanks!!
    JackyZLC
  • We have not seen this situation. What frequency band are you? Is the antenna plugged in?
Log in to reply
