Using RAK831 with native SPI
  • Hi
    I am able to use the RAK831 successful with r-pi when using FTDI.
    When trying to use native SPI, it didn't work. I found that the CE SPI line behaved as reset (one positive pulse when starting the GW), while no other GPIO pin behaves ad CE (low per each SPI transaction).
    When I used a different lora_gateway project, the CE line behaved fine, and I was able to run the test program with the RAK831, but then other functions such as lgw_auto_check and lgw_get_radio_id were not found.
    Can you please advise?
  • What is the native SPI you use? Is the lora_gateway project from LoRa official?
Log in to reply
