RAK831-915Mhz only accepts 868 frequencies
  • Hello,
    We set-up the RAK831 gateway to run on 915Mhz through TTN, however when we want to send data to the gateway it will only accept requests that are 868Mhz.
  • @patlabs
    I'm very sorry, based on the information you are currently providing, I can't tell you what is wrong with you. Let's sort out:
    1.What frequency band equipment are you buying?
    2.Did you configure it successfully? Is the global_conf.json file replaced by the 915 configuration?
    3.Is your node 915 frequency band?
    4.Maybe you should restart your TTN.
Log in to reply
