How does WisCore works?
  • 1:WisCore build in the AVS, the developer can use WisCore to build similar product like Amazon Echo Dot.
    2:Developer can program inside the WisCore base on OpenWRT to realize his own application code
    3:WisCore also provide the library base on RAK Igate Middleware, this is commercial level SDK for home automation application.
    4:WisCore compatible to Arduino Shield,you can use UART to communication with Arduino core to leverage the plenty demos base on Arduino
    5:WisCore can communicate with Raspberry pi through Ethernet
