RAK811 Tracker with Sensor hc-sr04
  • Hi
    How will i go about using the trackerboard with a sensor hc-sr04.
    Does the board have 2 gpio pins that i can use, and what is the command to open a pin and close a pin on RAK.
    example
    pinMode(PA1,OUTPUT);  // Physical pin PA1 on the board ?
    pinMode(PA15,INPUT); / Physical pin PA15 on the board ?
    digitalWrite(PA1,LOW); // Pin PA1 |   LOW is off / HIGH is on ?
    digitalWrite(PA15,LOW); // Pin PA51
  • administrators
    I don't know what project you're using, but I see this comment: LOW is off | HIGH is on
    Regards!
Log in to reply
