RAK831 868MHz global_conf.json with GPS enabled
  • Hi.
    Can anyone provide working packet forwarder global_conf.json for RAK831 868Mhz board that has real GPS enabled? I have RPi converter board with GPS module.
    global_conf.json coming with packet forwarder returns warning "WARNING: [gps] read() returned value 0"
    Thanks ahead.
  • Have a look on the TTN forum under
    The hard RAK831 cafe part 2 below message no 80 there is quite a bit discussion on the GPS configuration.
  • @88bit Thank you. I was able to connect to GPS by enabling Serial interface using raspi-config utility and setting gps_port = 'ttyS0'.
Log in to reply
