LoRa Gateway Developer kit RAK831 - Can't login
Recently received the above kit. Successfully have it connected to WiFi network. Gets IP from DHCP server. SSH is enabled, port 22 is open (confirmed with nmap).
When SSH to device using pi/raspberry I get permission denied. Any ideas why user account changed from default or what it could be?
The official is not modified.
@xc.c I can't login using the default - any suggestions as opposed to starting from scratch? I had expected to receive the component parts and I was to assemble however the kit came completely assembled and software all installed, including packet forwarder etc.
So I inserted SD card into another machine, opened the file 'cmdline.txt' and added 'rw init=/bin/sh' to the end. Then entered su and passwd pi to change the pi password.
I then inspected the contents of /var/log/auth.log
pi@ttn-gateway:/var/log $ cat auth.log
The notable line is: "Mar 13 08:30:00 ttn-gateway passwd[1174]: pam_unix(passwd:chauthtok): password changed for pi"
I first powered the unit on Mar 25.Jun 21 10:11:29 raspberrypi systemd-logind[460]: New seat seat0.
Jun 21 10:11:34 raspberrypi login[598]: pam_unix(login:session): session opened for user pi by LOGIN(uid=0)
Jun 21 10:11:34 raspberrypi systemd-logind[460]: New session c1 of user pi.
Nov 7 08:12:50 raspberrypi sudo: pi : TTY=unknown ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/raspi-config nonint get_boot_splash
Nov 7 08:12:50 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 7 08:12:50 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Mar 13 08:29:43 ttn-gateway sshd[1056]: Accepted password for pi from 192.168.0.109 port 49711 ssh2
Mar 13 08:29:43 ttn-gateway sshd[1056]: pam_unix(sshd:session): session opened for user pi by (uid=0)
Mar 13 08:29:43 ttn-gateway systemd-logind[438]: New session c3 of user pi.
Mar 13 08:29:50 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/raspi-config
Mar 13 08:29:50 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Mar 13 08:30:19 ttn-gateway systemd-logind[446]: New seat seat0.
Mar 13 08:30:20 ttn-gateway sshd[584]: Server listening on 0.0.0.0 port 22.
Mar 13 08:30:20 ttn-gateway sshd[584]: Server listening on :: port 22.
Mar 13 08:30:23 ttn-gateway lightdm: pam_unix(lightdm-autologin:session): session opened for user pi by (uid=0)
Mar 13 08:30:23 ttn-gateway systemd-logind[446]: New session c1 of user pi.
Mar 13 08:30:23 ttn-gateway systemd: pam_unix(systemd-user:session): session opened for user pi by (uid=0)
Mar 13 08:30:25 ttn-gateway login[637]: pam_unix(login:session): session opened for user pi by LOGIN(uid=0)
Mar 13 08:30:25 ttn-gateway systemd-logind[446]: New session c2 of user pi.
Mar 13 08:30:27 ttn-gateway polkitd(authority=local): Registered Authentication Agent for unix-session:c1 (system bus name :1.8 [lxpolkit], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
Mar 13 08:30:31 ttn-gateway sshd[989]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=192.168.0.109 user=pi
Mar 13 08:30:33 ttn-gateway sshd[989]: Failed password for pi from 192.168.0.109 port 49725 ssh2
Mar 13 08:30:50 ttn-gateway sshd[989]: Accepted password for pi from 192.168.0.109 port 49725 ssh2
Mar 13 08:30:50 ttn-gateway sshd[989]: pam_unix(sshd:session): session opened for user pi by (uid=0)
Mar 13 08:30:50 ttn-gateway systemd-logind[446]: New session c3 of user pi.
Mar 13 08:31:02 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/opt/ttn-gateway/bin ; USER=root ; COMMAND=./start.sh
Mar 13 08:31:02 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Mar 13 08:31:11 ttn-gateway sudo: pam_unix(sudo:session): session closed for user root
Mar 13 08:31:24 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/opt/ttn-gateway/bin ; USER=root ; COMMAND=./start.sh
Mar 13 08:31:24 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Mar 13 08:30:17 ttn-gateway systemd-logind[453]: New seat seat0.
Mar 13 08:30:17 ttn-gateway sshd[539]: Server listening on 0.0.0.0 port 22.
Mar 13 08:30:17 ttn-gateway sshd[539]: Server listening on :: port 22.
Mar 13 08:30:21 ttn-gateway lightdm: pam_unix(lightdm-autologin:session): session opened for user pi by (uid=0)
Mar 13 08:30:21 ttn-gateway systemd-logind[453]: New session c1 of user pi.
Mar 13 08:30:21 ttn-gateway systemd: pam_unix(systemd-user:session): session opened for user pi by (uid=0)
Mar 13 08:30:22 ttn-gateway login[617]: pam_unix(login:session): session opened for user pi by LOGIN(uid=0)
Mar 13 08:30:22 ttn-gateway systemd-logind[453]: New session c2 of user pi.
Mar 13 08:30:24 ttn-gateway polkitd(authority=local): Registered Authentication Agent for unix-session:c1 (system bus name :1.8 [lxpolkit], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
Mar 13 08:30:32 ttn-gateway sudo: pi : TTY=unknown ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/rfkill block wifi
Mar 13 08:30:32 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 08:30:32 ttn-gateway sudo: pam_unix(sudo:session): session closed for user root
Mar 13 08:30:34 ttn-gateway sudo: pi : TTY=unknown ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/rfkill unblock wifi
Mar 13 08:30:34 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 08:30:34 ttn-gateway sudo: pam_unix(sudo:session): session closed for user root
Mar 13 08:30:56 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/opt/ttn-gateway/bin ; USER=root ; COMMAND=./start.sh
Mar 13 08:30:56 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 08:30:16 ttn-gateway systemd-logind[434]: New seat seat0.
Mar 13 08:30:17 ttn-gateway sshd[533]: Server listening on 0.0.0.0 port 22.
Mar 13 08:30:17 ttn-gateway sshd[533]: Server listening on :: port 22.
Mar 13 08:30:20 ttn-gateway lightdm: pam_unix(lightdm-autologin:session): session opened for user pi by (uid=0)
Mar 13 08:30:20 ttn-gateway systemd-logind[434]: New session c1 of user pi.
Mar 13 08:30:20 ttn-gateway systemd: pam_unix(systemd-user:session): session opened for user pi by (uid=0)
Mar 13 08:30:22 ttn-gateway login[612]: pam_unix(login:session): session opened for user pi by LOGIN(uid=0)
Mar 13 08:30:22 ttn-gateway systemd-logind[434]: New session c2 of user pi.
Mar 25 14:17:01 ttn-gateway CRON[1039]: pam_unix(cron:session): session opened for user root by (uid=0)
Mar 25 14:17:01 ttn-gateway CRON[1039]: pam_unix(cron:session): session closed for user root
Mar 25 14:17:40 ttn-gateway sshd[1055]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=android-ce90b4946731afa9.internal.tenwalls.com user=pi
Mar 25 14:17:42 ttn-gateway sshd[1055]: Failed password for pi from 192.168.1.101 port 46652 ssh2
Mar 25 14:17:52 ttn-gateway sshd[1055]: Failed password for pi from 192.168.1.101 port 46652 ssh2
Mar 25 14:18:04 ttn-gateway sshd[1055]: Failed password for pi from 192.168.1.101 port 46652 ssh2
Mar 25 14:18:09 ttn-gateway sshd[1055]: Received disconnect from 192.168.1.101: 11: Closed due to user request. [preauth]
Mar 25 14:18:09 ttn-gateway sshd[1055]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=android-ce90b4946731afa9.internal.tenwalls.com user=pi
Mar 25 14:19:30 ttn-gateway sshd[1061]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=android-ce90b4946731afa9.internal.tenwalls.com user=pi
Mar 25 14:19:32 ttn-gateway sshd[1061]: Failed password for pi from 192.168.1.101 port 46653 ssh2
Mar 25 14:19:37 ttn-gateway sshd[1061]: Failed password for pi from 192.168.1.101 port 46653 ssh2
Mar 25 14:19:39 ttn-gateway sshd[1061]: Failed password for pi from 192.168.1.101 port 46653 ssh2
Mar 25 14:19:49 ttn-gateway sshd[1061]: Failed password for pi from 192.168.1.101 port 46653 ssh2
Mar 25 14:40:41 ttn-gateway sshd[1076]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=android-ce90b4946731afa9.internal.tenwalls.com user=root
Mar 25 14:40:44 ttn-gateway sshd[1076]: Failed password for root from 192.168.1.101 port 46870 ssh2
Mar 25 14:40:49 ttn-gateway sshd[1076]: Failed password for root from 192.168.1.101 port 46870 ssh2
Mar 25 14:40:59 ttn-gateway sshd[1076]: Failed password for root from 192.168.1.101 port 46870 ssh2
Mar 25 14:41:02 ttn-gateway sshd[1076]: Received disconnect from 192.168.1.101: 11: Closed due to user request. [preauth]
Mar 25 14:41:02 ttn-gateway sshd[1076]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=android-ce90b4946731afa9.internal.tenwalls.com user=root
Mar 25 14:52:13 ttn-gateway sshd[1087]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=android-ce90b4946731afa9.internal.tenwalls.com user=root
Mar 25 14:52:15 ttn-gateway sshd[1087]: Failed password for root from 192.168.1.101 port 47929 ssh2
Mar 25 14:17:06 ttn-gateway systemd-logind[441]: New seat seat0.
Mar 25 14:17:06 ttn-gateway sshd[572]: Server listening on 0.0.0.0 port 22.
Mar 25 14:17:06 ttn-gateway sshd[572]: Server listening on :: port 22.
Mar 25 14:17:10 ttn-gateway lightdm: pam_unix(lightdm-autologin:session): session opened for user pi by (uid=0)
Mar 25 14:17:10 ttn-gateway systemd-logind[441]: New session c1 of user pi.
Mar 25 14:17:10 ttn-gateway systemd: pam_unix(systemd-user:session): session opened for user pi by (uid=0)
Mar 25 14:17:11 ttn-gateway login[618]: pam_unix(login:session): session opened for user pi by LOGIN(uid=0)
Mar 25 14:17:11 ttn-gateway systemd-logind[441]: New session c2 of user pi.
Mar 25 14:17:13 ttn-gateway polkitd(authority=local): Registered Authentication Agent for unix-session:c1 (system bus name :1.8 [lxpolkit], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
Mar 25 15:09:05 ttn-gateway sshd[1004]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com user=pi
Mar 25 15:09:07 ttn-gateway sshd[1004]: Failed password for pi from 192.168.1.84 port 49390 ssh2
Mar 25 15:09:14 ttn-gateway sshd[1004]: Failed password for pi from 192.168.1.84 port 49390 ssh2
Mar 25 15:09:19 ttn-gateway sshd[1004]: Failed password for pi from 192.168.1.84 port 49390 ssh2
Mar 25 15:09:19 ttn-gateway sshd[1004]: Connection closed by 192.168.1.84 [preauth]
Mar 25 15:09:19 ttn-gateway sshd[1004]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com user=pi
Mar 25 15:09:28 ttn-gateway sshd[1078]: Invalid user raspberry from 192.168.1.84
Mar 25 15:09:28 ttn-gateway sshd[1078]: input_userauth_request: invalid user raspberry [preauth]
Mar 25 15:09:29 ttn-gateway sshd[1078]: pam_unix(sshd:auth): check pass; user unknown
Mar 25 15:09:29 ttn-gateway sshd[1078]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com
Mar 25 15:09:31 ttn-gateway sshd[1078]: Failed password for invalid user raspberry from 192.168.1.84 port 49392 ssh2
Mar 25 15:09:35 ttn-gateway sshd[1078]: pam_unix(sshd:auth): check pass; user unknown
Mar 25 15:09:37 ttn-gateway sshd[1078]: Failed password for invalid user raspberry from 192.168.1.84 port 49392 ssh2
Mar 25 15:09:37 ttn-gateway sshd[1078]: Connection closed by 192.168.1.84 [preauth]
Mar 25 15:09:37 ttn-gateway sshd[1078]: PAM 1 more authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com
Mar 25 15:14:55 ttn-gateway sshd[1087]: Invalid user Pi from 192.168.1.84
Mar 25 15:14:55 ttn-gateway sshd[1087]: input_userauth_request: invalid user Pi [preauth]
Mar 25 15:14:59 ttn-gateway sshd[1087]: pam_unix(sshd:auth): check pass; user unknown
Mar 25 15:14:59 ttn-gateway sshd[1087]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com
Mar 25 15:15:00 ttn-gateway sshd[1087]: Failed password for invalid user Pi from 192.168.1.84 port 49632 ssh2
Mar 25 15:15:05 ttn-gateway sshd[1087]: pam_unix(sshd:auth): check pass; user unknown
Mar 25 15:15:06 ttn-gateway sshd[1087]: Failed password for invalid user Pi from 192.168.1.84 port 49632 ssh2
Mar 25 15:15:10 ttn-gateway sshd[1087]: pam_unix(sshd:auth): check pass; user unknown
Mar 25 15:15:12 ttn-gateway sshd[1087]: Failed password for invalid user Pi from 192.168.1.84 port 49632 ssh2
Mar 25 15:15:12 ttn-gateway sshd[1087]: Connection closed by 192.168.1.84 [preauth]
Mar 25 15:15:12 ttn-gateway sshd[1087]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com
Mar 25 15:16:14 ttn-gateway sshd[1093]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com user=pi
Mar 25 15:16:16 ttn-gateway sshd[1093]: Failed password for pi from 192.168.1.84 port 49634 ssh2
Mar 25 15:16:22 ttn-gateway sshd[1093]: Failed password for pi from 192.168.1.84 port 49634 ssh2
Mar 25 15:16:23 ttn-gateway sshd[1093]: Connection closed by 192.168.1.84 [preauth]
Mar 25 15:16:23 ttn-gateway sshd[1093]: PAM 1 more authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com user=pi
Mar 25 15:16:28 ttn-gateway sshd[1098]: Invalid user Pi from 192.168.1.84
Mar 25 15:16:28 ttn-gateway sshd[1098]: input_userauth_request: invalid user Pi [preauth]
Mar 25 15:16:31 ttn-gateway sshd[1098]: pam_unix(sshd:auth): check pass; user unknown
Mar 25 15:16:31 ttn-gateway sshd[1098]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com
Mar 25 15:16:33 ttn-gateway sshd[1098]: Failed password for invalid user Pi from 192.168.1.84 port 49636 ssh2
Mar 25 15:16:34 ttn-gateway sshd[1098]: Connection closed by 192.168.1.84 [preauth]
Mar 25 15:16:43 ttn-gateway sshd[1102]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com user=root
Mar 25 15:16:45 ttn-gateway sshd[1102]: Failed password for root from 192.168.1.84 port 49638 ssh2
Mar 25 15:16:50 ttn-gateway sshd[1102]: Failed password for root from 192.168.1.84 port 49638 ssh2
Mar 25 15:16:53 ttn-gateway sshd[1102]: Failed password for root from 192.168.1.84 port 49638 ssh2
Mar 25 15:16:53 ttn-gateway sshd[1102]: Connection closed by 192.168.1.84 [preauth]
Mar 25 15:16:53 ttn-gateway sshd[1102]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com user=root
Mar 25 15:17:01 ttn-gateway CRON[1108]: pam_unix(cron:session): session opened for user root by (uid=0)
Mar 25 15:17:01 ttn-gateway CRON[1108]: pam_unix(cron:session): session closed for user root
Mar 25 15:19:02 ttn-gateway sshd[1126]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com user=pi
Mar 25 15:19:04 ttn-gateway sshd[1126]: Failed password for pi from 192.168.1.84 port 51670 ssh2
Mar 25 15:19:05 ttn-gateway sshd[1126]: Connection closed by 192.168.1.84 [preauth]
Mar 25 15:17:06 ttn-gateway systemd-logind[436]: New seat seat0.
Mar 25 15:17:06 ttn-gateway sshd[550]: Server listening on 0.0.0.0 port 22.
Mar 25 15:17:06 ttn-gateway sshd[550]: Server listening on :: port 22.
Mar 25 15:17:10 ttn-gateway lightdm: pam_unix(lightdm-autologin:session): session opened for user pi by (uid=0)
Mar 25 15:17:10 ttn-gateway systemd-logind[436]: New session c1 of user pi.
Mar 25 15:17:10 ttn-gateway systemd: pam_unix(systemd-user:session): session opened for user pi by (uid=0)
Mar 25 15:17:11 ttn-gateway login[617]: pam_unix(login:session): session opened for user pi by LOGIN(uid=0)
Mar 25 15:17:11 ttn-gateway systemd-logind[436]: New session c2 of user pi.
Mar 25 15:17:13 ttn-gateway polkitd(authority=local): Registered Authentication Agent for unix-session:c1 (system bus name :1.8 [lxpolkit], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
Mar 25 15:27:31 ttn-gateway sshd[1007]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com user=pi
Mar 25 15:27:33 ttn-gateway sshd[1007]: Failed password for pi from 192.168.1.84 port 53692 ssh2
Mar 25 15:27:40 ttn-gateway sshd[1007]: Failed password for pi from 192.168.1.84 port 53692 ssh2
Mar 25 15:27:41 ttn-gateway sshd[1007]: Connection closed by 192.168.1.84 [preauth]
Mar 25 15:27:41 ttn-gateway sshd[1007]: PAM 1 more authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=dev1.internal.tenwalls.com user=pi
Mar 25 15:17:05 ttn-gateway systemd-logind[438]: New seat seat0.
Mar 25 15:17:06 ttn-gateway sshd[528]: Server listening on 0.0.0.0 port 22.
Mar 25 15:17:06 ttn-gateway sshd[528]: Server listening on :: port 22.
Mar 25 15:17:08 ttn-gateway login[602]: pam_unix(login:session): session opened for user pi by LOGIN(uid=0)
Mar 25 15:17:08 ttn-gateway systemd-logind[438]: New session c1 of user pi.
Mar 25 15:17:08 ttn-gateway systemd: pam_unix(systemd-user:session): session opened for user pi by (uid=0)
Mar 25 15:17:09 ttn-gateway lightdm: pam_unix(lightdm-autologin:session): session opened for user pi by (uid=0)
Mar 25 15:17:09 ttn-gateway systemd-logind[438]: New session c2 of user pi.
Mar 25 15:17:13 ttn-gateway polkitd(authority=local): Registered Authentication Agent for unix-session:c2 (system bus name :1.8 [lxpolkit], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
Mar 26 10:31:39 ttn-gateway sshd[1048]: Accepted password for pi from 192.168.1.84 port 43626 ssh2
Mar 26 10:31:39 ttn-gateway sshd[1048]: pam_unix(sshd:session): session opened for user pi by (uid=0)
Mar 26 10:31:39 ttn-gateway systemd-logind[438]: New session c3 of user pi.
Mar 26 10:32:09 ttn-gateway passwd[1076]: pam_unix(passwd:chauthtok): authentication failure; logname=pi uid=1000 euid=0 tty= ruser= rhost= user=pi
Mar 26 10:32:16 ttn-gateway passwd[1079]: pam_unix(passwd:chauthtok): authentication failure; logname=pi uid=1000 euid=0 tty= ruser= rhost= user=pi
Mar 26 10:32:21 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/passwd pi
Mar 26 10:32:21 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Mar 26 10:32:27 ttn-gateway passwd[1086]: pam_unix(passwd:chauthtok): password changed for pi
Mar 26 10:32:27 ttn-gateway sudo: pam_unix(sudo:session): session closed for user root
Mar 26 10:35:35 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/grep pi
Mar 26 10:35:35 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Mar 26 10:35:38 ttn-gateway sudo: pam_unix(sudo:session): session closed for user root
Mar 26 10:35:49 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/grep pi
Mar 26 10:35:49 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Mar 26 10:35:51 ttn-gateway sudo: pam_unix(sudo:session): session closed for user root
Mar 26 10:36:04 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/passwd -S -a
Mar 26 10:36:04 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Mar 26 10:36:04 ttn-gateway sudo: pam_unix(sudo:session): session closed for user root
Mar 26 10:37:01 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/passwd -S -a
Mar 26 10:37:01 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Mar 26 10:37:01 ttn-gateway sudo: pam_unix(sudo:session): session closed for user root
Mar 26 10:37:22 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/dmesg
Mar 26 10:37:22 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Mar 26 10:37:22 ttn-gateway sudo: pam_unix(sudo:session): session closed for user root
Mar 26 10:43:36 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/var/log ; USER=root ; COMMAND=/bin/cat auth.log
Mar 26 10:43:36 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Mar 26 10:43:36 ttn-gateway sudo: pam_unix(sudo:session): session closed for user root
Mar 26 10:44:41 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/var/log ; USER=root ; COMMAND=/usr/bin/apt-get upate
Mar 26 10:44:41 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Mar 26 10:44:41 ttn-gateway sudo: pam_unix(sudo:session): session closed for user root
Mar 26 10:44:44 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/var/log ; USER=root ; COMMAND=/usr/bin/apt-get update
Mar 26 10:44:44 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Mar 26 10:45:34 ttn-gateway sudo: pam_unix(sudo:session): session closed for user root
Mar 26 10:45:45 ttn-gateway sudo: pi : TTY=pts/0 ; PWD=/var/log ; USER=root ; COMMAND=/usr/bin/apt-get upgrade
Mar 26 10:45:45 ttn-gateway sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Mar 26 10:59:08 ttn-gateway sshd[528]: Received signal 15; terminating.
Mar 26 10:59:08 ttn-gateway sshd[27376]: Server listening on 0.0.0.0 port 22.
Mar 26 10:59:08 ttn-gateway sshd[27376]: Server listening on :: port 22.
Mar 26 11:00:30 ttn-gateway sudo: pam_unix(sudo:session): session closed for user root
@xc.c See auth.log post
Same problem here. I just received the rak831 packaged with the converter board and the rp3 and cannot login with ssh. Tried the default pi/raspberry but get an 'access denied' error. I can change the password but think I'll just wipe the card...not really trusting what it is running. Anyone know the password RAK is shipping with or has this image been tampered with?
Same problem here, apparently the pi password is not raspberry.
You can use Raspberry Pi's official system and follow the tutorial here to create a RAK831 connection to the TTN system.
https://www.thethingsnetwork.org/labs/story/rak831-lora-gateway-from-package-to-online
