RAK_LB801N not working
  • Hi There
    I've got a Lora button, but can't have it working correctly, I tried on TTN first so I changed to my local LoraWAN server and or at least it works
    Sometime it works then stop working after 5/10 min and sometimes it does not work
    Here what I've done
    at+version
    OK2.0.2.1
    at+mode=0
    OK
    at+set_config=dev_eui:4444......
    OK
    at+set_config=app_eui:70B3D57...
    OK
    at+set_config=app_key:24326DF......
    OK
    at+join=otaa
    OK
    at+reset=0
    OK
    Welcome to RAK_LB801N
    After join seen on server (I can see the join request on server )
    I started to play with buttons
    Key2 press
    Tx OK: 53 01 00 01 00 00 00 64
    Key3 press
    Tx OK: 53 01 00 00 01 00 00 64
    As indicated TX is OK but I don't see any frame going to my server.
    Anyone has encountered this issue? Any beta firmware available?
  • Hi,
    I do not own and have not played with the button (yet), but the at+reset command seems counter-intuitive to me as a rak811-user.
    have you tried sending directly after the at+join=otaa command?
  • administrators
    @Charles What is your LoRa gateway device? What frequency band are you using?
Log in to reply
