RAK811 Tracker
  • I need some help in understanding how to read the GPS / MEMS data out of RAK811 tracker board without using LORA, as a standalone board.
    Is it possible to use serial ports or any pins on the Tracker Board to get access to this data without using AT command set.
    Please share the PINS and the wiring required to connect this board to Raspberry PI 3, so we could collect that data much faster.
  • administrators
    Hello, RAK811 Tracker program is open source, if you do not want to use LoRaWAN sensor data transmission, then you can get the device data obtained through the serial port or I2C way to send to other devices, these you can program.
Log in to reply
