RAK831 output error
  • I followed this document but still in error. kindly help
    Document Followed
    http://docs.rakwireless.com/en/RAK831 LoRa Gateway/Application Notes/Getting started with the RAK 831 Lora Gateway and RPi3.pdf
    Output Error
    pi@192:/opt/ttn-gateway/packet_forwarder/basic_pkt_fwd $ ./basic_pkt_fwd
    *** Basic Packet Forwarder for Lora Gateway ***
    Version: 2.1.0
    Version: 3.1.0; Options: ftdi;
    INFO: Little endian host
    INFO: Configuring TX LUT with 16 indexes
    INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1
    INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0
    INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
    INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
    INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
    INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
    INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
    INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
    INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
    INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
    INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
    INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
    INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
    INFO: gateway MAC address is configured to AA555A0000000000
    INFO: server hostname or IP address is configured to "127.0.0.1"
    INFO: upstream port is configured to "1680"
    INFO: downstream port is configured to "1680"
    INFO: downstream keep-alive interval is configured to 10 seconds
    INFO: statistics display interval is configured to 30 seconds
    INFO: upstream PUSH_DATA time-out is configured to 100 ms
    INFO: found local configuration file local_conf.json, parsing it
    INFO: redefined parameters will overwrite global parameters
    INFO: local_conf.json does not contain a JSON object named SX1301_conf
    INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
    INFO: gateway MAC address is configured to AA555A0000000101
    ERROR: [main] failed to start the concentrator
  • what are the commands you type it? what is the purpose of this command? what exactly you are trying to do here?
  • administrators
    You did not submit the remote json file on this github : https://github.com/ttn-zh/gateway-remote-config
Log in to reply
