Flylink HD&AV change a new ssid with PSK on wireless hdmi extender
  • This document is only using for Flylink HD and Flylink AV .
    Flylink HD : RAK566(TX) and RA554(RX). Flylink AV : RAK553(TX) and RAK554(RX).
    RAK5610 is same with RAK554 including firmware and Hardware.
    1 RAK554 PIN Definition
    2 RAK554 Dip switch definition
    There are 6 group Dial-up in the module . ON direction is showing low-level ,marked as 0.
    When The Dial-up is on the opposite direcetion ,that is showing high-level,marked as 1 .
    The dial-up flag order is 1-6,marked as sw1-6.
    The function definition is followed :
    The default band is Band4. That is to say channel 149.
    Sw1 is using for WPS function . If you want to use this function , you need do the following steps.
    Step1 : Whatever the SW1 level , set SW1 into low-level more than 1 second .
    Step2 : Then Set SW1 into high-level .
    Step3 : The Wifi light will blink.that is showing you have step into the WPS mode.
    After power on the module,please scan the AP: FS_5G_AP_xxxxxx or Flylink_xxxxxx(please make sure your smartphone supporting 5G SSID). X means MAC address.
    3 How to change SSID and PSK
    RAK553 will work as OPEN network .if you have to change the SSID and PSK .please following the steps strictly. Note: Once you change the network parameters, you have to make a new connection with Transmitter. Please reference the Module Pair.
    Step 1 : Power on RAK553.
    Step 2: Waiting for the Blue LED turn on and that means the restart completed .
    Step 3: Scan and connect the AP with your 5G WIFI device ,such as phone,pad ,or PC .
    Step 4: Open broswer and input the following HTTP command in the address bar and Enter . you need to input the user and password which both are admin. If you get the “value”:”0”, that means the configuration succeed.
    HTTP Command: Encryption :
    192.168.100.1/param.cgi?action=update&group=wifi&ap_ssid=RAK_5G_AP_XXXXX%20%23=BRING&ap_auth_mode=WPA2PSK&ap_encrypt_type=AES&ap_auth_key=RAK12345
    Function:
    Change the network to WAP2 encryption and a new SSID .
    Key point(Red words) :
    IP address : 192.168.100.1. Must be 192.168.100.1!
    SSID : RAK_5G_AP_XXXXX. Change to what you want ,such as SMD_5G_AP_CC566A. we can only support the following chars. but we suggest you’d sue the letters and numbers .
    ./abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ_-+=&1234567890@[]?%#
    PSK : RAK12345. Change to what you want ,such as 1234567890 . the length must be in the range from 8 char to 32 char. we can only support the following chars.
    Note: please don’t change any other words !
    HTTP Command:Open :
    192.168.100.1/param.cgi?action=update&group=wifi&ap_ssid=RAK_5G_AP_XXXXX%20%23=BRING&ap_auth_mode=OPEN&ap_encrypt_type=NONE
    Function:
    Change the network to OPEN mode and a new SSID .
    SSID : RAK_5G_AP_XXXXX. Change to what you want ,such as SMD_5G_AP_CC566A. we can only support the following chars.but we suggest you’d sue the letters and numbers .
    4 Example
    Change the network to OPEN mode and a new SSID: SMD_5G_AP_CC566A .
    Command:
    192.168.100.1/param.cgi?action=update&group=wifi&ap_ssid=SMD_5G_AP_CC566A%20%23=BRING&ap_auth_mode=OPEN&ap_encrypt_type=NONE
    Input the command in Broswer and input the user and password with admin.
    HTTP Successful Return:
