SubBand selection command missing in RAK811
  • Multitech LoRa Conduit can only listen to 1/8 of the spectrum at a time, they call it SubBand and each is numerated 1-8. A command to limit the frequencies (or select the subBand) in which the at+join=otaa or at+send commands are transmitted is missing.
  • Hi FerCossio
    What's the soft version of your RAK811?
    Yes, Multitech LoRa Conduit can only listen 8 channels.
    because our module US915 support 72 channels , if your gateway not support all the channels , you should use set_config ch_list to enable the gateway support channels for example 0-7 channel. others should be closed
    for example:
    at+set_config=ch_list:7,off
    or
    at+set_config=ch_list:7,on,0,3
    and check
    at+get_config=ch_list
    Default, US915 up channel 0-63 902.3Mhz-914.9 0.2M step
    64-71 903.0MHz-914.2 1.6Mstep
  • This post is deleted!
  • I have tested the commands in ver. 1.0.3.5
    command:
    answer:
    3,off;4,off;5,off;6,off;7,off;8,off;9,off;10,off;11,off;12,off;13,off;14,off;15,off
    command:
    answer:
    ERROR-1
    at+set_config=ch_list:<any number>, on, 0,3 always fails
  • Hi FerCossio
    Your current use the version is the actility certificate 868M Firmware .
    Please test the attachment latest 915M Firmware.
    0_1490236399846_RAK811_V1023_RELEASE_915.bin
  • I'm receiving the same errror (ERROR-1) when trying to change the ch_list.
    Firmware is RAK811_V1023_RELEASE_868.bin
    What to do?
  • 868 Band need the customer frequency .
    at+set_config=ch_list:3,on,866200000,0,5
  • @junhua How do the overlapping freq. work (903MHz-914.2MHz)?
    In example: what happens when I turn up channels 4, 5, 6, 7, 8, 9, 10 but turn off channel 64?
  • @FerCossio Here seems no overlapping frequency , channels 4 -10 (903.1-904.3)with bandwith 125KHz datatate range dr0-3, channel 64 (903.0) with bandwith 500KHz,datarate fix dr4.
  • Please provide example to turn off all channels except 868,1 MHz.
    Thanks, Peter
  • @alviso you change the default channel ,shoud upgrade to new firmwave version V1026 .please see the examples
    at+set_config=ch_list:0,on,868100000,0,5
    at+set_config=ch_list:1,off
    at+set_config=ch_list:15,off
    http://www.rakwireless.com/en/download/RAK811 LoRa Module/Firmware upgrade
    http://docs.rakwireless.com/en/RAK811 LoRa Module/Software Development/RAK811 LoRa AT Command V1.3.pdf
  • I have configured my rak811 (RAK811_V1026_RELEASE_868.bin) to enable only channel 0 with frequency 868100000 and SF9 using
    at+set_config=ch_list:0,on,868100000,3,3
    but when I send a message it seems to use any available band (868.5, 867.3, 868.3...).
    I wanto to send all the messages in the 868.1 frequency because I am using a single channel gateway listening only to that frequency. How can I do it?
  • Ok, I think I have found a partial solution.
    I have configured all the channels as:
    at+set_config=ch_list:1,on,868100000,3,3
    at+set_config=ch_list:2,on,868100000,3,3
    at+set_config=ch_list:15,on,868100000,3,3
    And now all the messages are sent in the 868.1 frequency
  • I think there is some problem with the rak811 firmware.
    As you can see in the following image, only one of every two messages is really sent in the 868.1 freq; in other words, one message is sent properly, but the following message is always sent a bit drifted.
    alt text
Log in to reply
